BobCAD-CAM Logo
HomeSupportDownloadsPricing
BobNEST V3 a powerful true shape nesting system sheet optimizing functionality
About Us - Since 1985 Bob CAD-CAM has been dedicated to providing manufacturers just like you with powerful and easy to use CNC software. with the purpose of helping you effectively automate the machining process.. We now provide CNC G code for Milling, Lathe, Routing, Water Jet, Laser, Plasma and Wire EDM
BobCAD-CAM has been dedicated to providing manufacturers just like you, Since 1985 with powerful and easy to use CNC programming CAD-CAM software with the purpose of helping you effectively automate the machining process. We now provide CNC G & M Code for Milling, Lathe, Routing, Water Jet, Laser, Plasma and Wire EDM.Our CAD/CAM systems offer powerful CAD functionality for design combined with Toolpath and complete G Code producing functions that makes your CNC software programming simple.
Our BobART PRO-X ART CADCAM system allows you to create complete embossed sculptures on the fly directly from a picture as well as our Nesting system providing you with accurate and efficient sheet optimizing capabilities easily. Our CADCAM Training products are second to none and bring the professor to you! Whether you have a simple 2D job or a complex 3D mold to manufacture, BobCADCAM can help you increase profits and support Lean Manufacturing in your shop. We look forward to cutting parts with you from engraving and sign-making to plastic injection and other types of design & manufacturing! Nowhere in the world can you achieve this much CNC programming CAD/CAM power for the cost! See for yourself…
We look forward to helping you make chips out of the competition!
BobCAD-CAM
About Us
“Thank you for a very efficient and informative demo of Bobcad 2007. I find the new user interface for machining the most intuitive and best I have evaluated. The simplicity is deceiving. The amount setup flexibility and machining technology is superb.
The seamless interface to Rhino will be a great asset in our currently developing new approach to three dimensional CAD/CAM.
Best regards,
Max Waddoups
Strayer Voigt, Inc.
"We recently received an IGES file with special 3D curves on it with Engraving. In the past we would have had to have sub-contracted this work out, but thanks to the Bob CAD CAM software we were able to create all the 3D curves with skins on and generate programs for them, and also cut the necessary engraving for this type of work. We have just completed the job, and have found the shut off zones in the plastic to be absolutely perfect. In fact, in my 25 year career, I've never had these shut-off zones so good. We are ecstatic with the results and very excited with our BobCAD package. Please, if there are any further developments with this CADCAM package, please contact us."
Thank you once again,
Russell S.
New BobNEST
Higher Level Capabilities For Part Nesting
Maximize Useable Material And Cutting Down On Material Waste
Saving You Time And Money
BobNEST Version 3.0 is a powerful true shape nesting system that gives you faster, smarter sheet optimizing functionality so that you can increase your per-job profitability through higher yields on your nesting jobs.
Not only is this system easy to use it is fast in nesting your simple or complex parts.
TRY BOBNEST FREE
Features Include:
  • True Shape nesting
  • Support for Dados with 3D cutting Approach  NEW
  • Global rotation settings for higher efficiency control
  • Automatic drill hole nesting
  • Automatic inside and outside profile nesting
  • Use or Create multiple sheets of different sizes for thesame job
  • Part-in-Part nesting - smaller parts inside larger part openings  NEW
  • Simple Job Setup strategies for tools, stock, parts as well as your lead-in and out operations for machining through one easy to use dialog
  • Automatic radius and angular line lead-in and out for toolpath
  • Set Part Priorities for nesting  NEW
  • Track parts and material efficiency as well as left-over parts and material
  • Create stock margins and part-to-part separation
  • Filler Part  NEW
  • Cutting Simulation  NEW
  • Create and save tools and stock
  • Layer support in Version 21 BobCAD-CAM software for easy control in machining
  • Determine Cutting Patterns - Parallel or Zig Zag  NEW
click to see full size
BobNEST brings you powerful industry standard nesting functionality for your shop at an incredibly low cost. Simply select and load as many parts as needed and then setup how you would like to nest your parts. Leave the rest to BobNEST!
Try software demo free
Back to Top of Page
Privacy Policy     Refund Policy
       Visitor # 4464754           ..
