V19 SoftwareVersion 19 CAD-CAM incorporates Wire Frame, Surfaces and Solids into one with the primary goal of allowing you the ability to create clean toolpath and accurate g-code programs for imported surface or solids type files. V19 supports DXF, IGES and STEP files for the importing of surfaces or solid models for machining. CAM functionality includes customizable tool libraries, canned cycles as well as customizable drilling cycles through using simple visual basic scripting technology. The feature comparison below will provide you with a complete list of features.
You will also be relieved to know that there are NO MAINTENANCE FEES!
- DXF Import
- IGES Import
- Solids & Surfaces
- STEP Import
- Solids & Surfaces
- CAD-Design with Primitive Solids
- Solid Edit-Boolean Operations – Union, Difference & Intersection
- Automatic Stitch surfaces to Solid
- Automatic Un-Stitch surfaces from Solid
- Definition boundary machining
- Solid or Surface Toolpath wizard
- Solid part rendering
- Isolation Surface Machining
- Offset Surfaces & Solids
- Pocketing with island avoidance
- Automatic Spiral & Horizontal toolpath
- Profiling - Open & Closed Shapes
- Engraving
- Bolthole Patterns – Grid & Circular
- Horizontal Z Axis Roughing
- Horizontal Z Axis Finishing
- Spiral Z Axis Roughing
- Spiral Z Axis Finishing
- Surface Roughing – Skin Surface, Revolved Surface, Swept Surface, Ruled Surfaces, Radial Surfaces
- Surface Finishing – Skin Surface, Revolved Surface, Swept Surface, Ruled Surfaces, Radial Surfaces
- Spiral Skin Surface Toolpath
- Gears Creation & Machining
- Clean Circle – Roughing & Finishing
- Project Text Onto Surfaces – Roughing and Finishing
- Project Text To Curves – Roughing & Finishing
- Surface Machine Around Raised Text – Roughing & Finishing
- Direct Surface Toolpath To Wireframe
- 4th Axis Indexing
- 4th Axis Rotary
- RS 232 Communications – Fully Customizable by the operator
- DNC Communications - Fully Customizable by the operator
- Post Processor Configurations - Fully Customizable by the operator
- Post Processor Library – Available to all customers at no extra charge
- Customizable CAM Menus
- Customizable Drill Cycles
- Customizable Tool Library
- Customizable Tool Boxes & Icons
- Graphical Tool Rendering
- G-Code Editor
- Color Coded NC Codes – Operator Definable
- Solid NC Verification/Part Simulation
- NC Code Backplot
- Drilling
- Tapping
- Boring
- Reverse Boring
- Peck Drilling
- Reaming
- Visual Basic Scripting Capability
- Create & Record Operations
- Script Library
- Roughing
- Finishing
- Grooving
- Slotting
- Facing
- Collision Detection
- Diameter Programming
- NC/G-Code Generation
- Complete Training Manual
Version 19 Features
File Import
Solid Modeling
2 Axis Milling
3 Axis Milling
4 Axis Milling
CAM & Communications
Verification
Hole Making
Visual Basic
2 Axis Lathe
Training
Training Seminars Available – On Location or at our International Training School.
Call 877-262-2231 or 727-442-3554 for availability and scheduling
