BobCAD-CAM Logo
HomeSupportDownloadsPricing
About Us - Since 1985 Bob CAD-CAM has been dedicated to providing manufacturers just like you with powerful and easy to use CNC software. with the purpose of helping you effectively automate the machining process.. We now provide CNC G code for Milling, Lathe, Routing, Water Jet, Laser, Plasma and Wire EDM
BobCAD-CAM has been dedicated to providing manufacturers just like you, Since 1985 with powerful and easy to use CNC programming CAD-CAM software with the purpose of helping you effectively automate the machining process. We now provide CNC G & M Code for Milling, Lathe, Routing, Water Jet, Laser, Plasma and Wire EDM.Our CAD/CAM systems offer powerful CAD functionality for design combined with Toolpath and complete G Code producing functions that makes your CNC software programming simple.
Our BobART PRO-X ART CADCAM system allows you to create complete embossed sculptures on the fly directly from a picture as well as our Nesting system providing you with accurate and efficient sheet optimizing capabilities easily. Our CADCAM Training products are second to none and bring the professor to you! Whether you have a simple 2D job or a complex 3D mold to manufacture, BobCADCAM can help you increase profits and support Lean Manufacturing in your shop. We look forward to cutting parts with you from engraving and sign-making to plastic injection and other types of design & manufacturing! Nowhere in the world can you achieve this much CNC programming CAD/CAM power for the cost! See for yourself…
We look forward to helping you make chips out of the competition!
BobCAD-CAM
About Us
“Thank you for a very efficient and informative demo of Bobcad 2007. I find the new user interface for machining the most intuitive and best I have evaluated. The simplicity is deceiving. The amount setup flexibility and machining technology is superb.
The seamless interface to Rhino will be a great asset in our currently developing new approach to three dimensional CAD/CAM.
Best regards,
Max Waddoups
Strayer Voigt, Inc.
"We recently received an IGES file with special 3D curves on it with Engraving. In the past we would have had to have sub-contracted this work out, but thanks to the Bob CAD CAM software we were able to create all the 3D curves with skins on and generate programs for them, and also cut the necessary engraving for this type of work. We have just completed the job, and have found the shut off zones in the plastic to be absolutely perfect. In fact, in my 25 year career, I've never had these shut-off zones so good. We are ecstatic with the results and very excited with our BobCAD package. Please, if there are any further developments with this CADCAM package, please contact us."
Thank you once again,
Russell S.
19 CAD-CAM incorporates Wire Frame, Surfaces and Solids toolpath and accurate g-code
Bob CadCam Hobby ProV19 Software
Version 19 CAD-CAM incorporates Wire Frame, Surfaces and Solids into one with the primary goal of allowing you the ability to create clean toolpath and accurate g-code programs for imported surface or solids type files. V19 supports DXF, IGES and STEP files for the importing of surfaces or solid models for machining. CAM functionality includes customizable tool libraries, canned cycles as well as customizable drilling cycles through using simple visual basic scripting technology. The feature comparison below will provide you with a complete list of features.
You will also be relieved to know that there are NO MAINTENANCE FEES!
    Try Hobby Pro FREE
    Version 19 Features
    File Import
  • DXF Import
  • IGES Import
  • Solids & Surfaces
  • STEP Import
  • Solids & Surfaces
  • Solid Modeling
  • CAD-Design with Primitive Solids
  • Solid Edit-Boolean Operations – Union, Difference & Intersection
  • Automatic Stitch surfaces to Solid
  • Automatic Un-Stitch surfaces from Solid
  • Definition boundary machining
  • Solid or Surface Toolpath wizard
  • Solid part rendering
  • Isolation Surface Machining
  • Offset Surfaces & Solids
  • 2 Axis Milling
  • Pocketing with island avoidance
  • Automatic Spiral & Horizontal toolpath
  • Profiling - Open & Closed Shapes
  • Engraving
  • Bolthole Patterns – Grid & Circular
  • 3 Axis Milling
  • Horizontal Z Axis Roughing
  • Horizontal Z Axis Finishing
  • Spiral Z Axis Roughing
  • Spiral Z Axis Finishing
  • Surface Roughing – Skin Surface, Revolved Surface, Swept Surface, Ruled Surfaces, Radial Surfaces
  • Surface Finishing – Skin Surface, Revolved Surface, Swept Surface, Ruled Surfaces, Radial Surfaces
  • Spiral Skin Surface Toolpath
  • Gears Creation & Machining
  • Clean Circle – Roughing & Finishing
  • Project Text Onto Surfaces – Roughing and Finishing
  • Project Text To Curves – Roughing & Finishing
  • Surface Machine Around Raised Text – Roughing & Finishing
  • Direct Surface Toolpath To Wireframe
  • 4 Axis Milling
  • 4th Axis Indexing
  • 4th Axis Rotary
  • CAM & Communications
  • RS 232 Communications – Fully Customizable by the operator
  • DNC Communications - Fully Customizable by the operator
  • Post Processor Configurations - Fully Customizable by the operator
  • Post Processor Library – Available to all customers at no extra charge
  • Customizable CAM Menus
  • Customizable Drill Cycles
  • Customizable Tool Library
  • Customizable Tool Boxes & Icons
  • Graphical Tool Rendering
  • G-Code Editor
  • Color Coded NC Codes – Operator Definable
  • Verification
  • Solid NC Verification/Part Simulation
  • NC Code Backplot
  • Hole Making
  • Drilling
  • Tapping
  • Boring
  • Reverse Boring
  • Peck Drilling
  • Reaming
  • Visual Basic
  • Visual Basic Scripting Capability
  • Create & Record Operations
  • Script Library
  • 2 Axis Lathe
  • Roughing
  • Finishing
  • Grooving
  • Slotting
  • Facing
  • Collision Detection
  • Diameter Programming
  • NC/G-Code Generation
  • Training
  • Complete Training Manual
  • Training Seminars Available – On Location or at our International Training School.
    Call 877-262-2231 or 727-442-3554 for availability and scheduling
Try software demo free
Back to Top of Page
Privacy Policy     Refund Policy
       Visitor # 4464695           ..
